Ga door naar hoofdinhoud
iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement
Wat je nodig hebt
  1. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, Bottom Plate: stap 1, afbeelding 1 van 1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement: stap 2, afbeelding 1 van 1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, Bottom Plate Housing: stap 4, afbeelding 1 van 2 iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, Bottom Plate Housing: stap 4, afbeelding 2 van 2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement: stap 5, afbeelding 1 van 2 iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement: stap 5, afbeelding 2 van 2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  6. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, PRAM Battery: stap 6, afbeelding 1 van 2 iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, PRAM Battery: stap 6, afbeelding 2 van 2
    • Gently remove the battery from its holder using the plastic opening tool.
    • Insert new battery.
    • Clean and re-apply thermal paste to the heat sink areas circled in orange. See Step 15 in iMac G4 17" Model M9168LLA Hard Drive Replacement for better photos and description.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Justin
303 Reputatie
3 handleidingen geschreven
Cal Poly, Team 21-22, Maness Fall 2011 Lid van Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 Leden
13 handleidingen geschreven
7 opmerkingen
We are not allowed to use screwdrivers to pry open stuff. Unfortunately, that is exactly what we did in step 6 of Dissasembling the back up battery
David Hunter - Antwoord
Don't you need to replace the thermal paste?
adoug27 - Antwoord
Yes you do in the areas circled in orange. I'd also recommend changing the paste under the heatsink itself as that will probably be dried up.
yotoprules -
I love my very first Mac ever, it is still working. After a couple of time living with its amnesia (forgot time and what else…) I’ve decided to replace the battery. Thanks for this helpful article. It made it easy to me to replace the battery.
Roland Brezina - Antwoord
Good guide ! less than 20 minutes to change the battery, cleaning the interior included !!
SURIN Dominique - Antwoord
Any thoughts? I replaced the battery and reapplied the thermal grease. iMac still won’t turn on.
Jessica - Antwoord
Did you check voltage of the new battery? Should be 3.6v.
Otherwise it could be a logic board or PSU problem.
yotoprules -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 156
Altijd: 11,427
