Ga door naar hoofdinhoud
iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement
Wat je nodig hebt
  1. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate: stap 1, afbeelding 1 van 1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: stap 2, afbeelding 1 van 1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate Housing: stap 4, afbeelding 1 van 2 iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate Housing: stap 4, afbeelding 2 van 2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: stap 5, afbeelding 1 van 2 iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: stap 5, afbeelding 2 van 2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  6. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Logic Board Assembly: stap 6, afbeelding 1 van 1
    • Gently remove the cables marked in red.
  7. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: stap 7, afbeelding 1 van 1
    • Remove the three metal 10mm T-15 screws.
    • Remove the one nylon 10mm T-15 screw.
  8. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: stap 8, afbeelding 1 van 1
    • Using thumbs and forefingers, firmly grasp the battery holder in one hand while grasping the metal bar in the other. Gently lift and pull the logic board to release it.
    i followed instructions and the logic board is stuck in there! can’t find any answers on the web either. any ideas?
    the biohazard - Antwoord
Conclusie
9 andere personen hebben deze handleiding voltooid.
Justin
303 Reputatie
3 handleidingen geschreven
Cal Poly, Team 21-22, Maness Fall 2011 Lid van Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 Leden
13 handleidingen geschreven
Één opmerking
We need to say what cables to remove in step 6 of Logic Board Assembly
Courtney - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 61
Altijd: 10,560
