Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Position the computer so that all three screws on the underside of the display are accessible. This may be upright or laid flat with the screen face down on a soft surface.
Unscrew the three underside 1.5 mm hex screws with the tight fitting, hexagonal screw head.
Separate the front panel of display from base by firmly, but carefully, applying pressure upward. As a result, the two panels should slide apart.
While the cords are still connected, access the inter-workings of the display from the top.
The red circle indicates the LED cable.
The blue circle indicates the inverter cable.
The yellow circle indicates TMDS connector.
Disconnect the inverter cable by grasping the chords on each side of the white connection and gently pull your hands away from each other.
The next cord to unplug between the two panels of the display is the inverter cable. This will be located under the inverter closer to the bottom of the screen and will have only two cables connecting at a smaller white connection.
Like the inverter cable, grasp each side of the white connection and gently unplug the inverter cable.
The third, and final, cable you will need to unplug is the TMDS connector. This is located under a rectangular strip of black tape that has a gray and black cord coming out of one end.
Peel back the black tape, starting at the end with the cords protruding out.
Under the black tape, you will see the gray and black cords going into a connection that looks like it is wrapped in aluminum foil. Grasp that connection and pull carefully in the downward direction toward the bottom of the display.
Now that you have unplugged all of the cables, you can lay the front panel of the display face down on a soft surface.
Next, you will unscrew the four 5 mm T-10 screws located at the corners of the display.
Once the four screws are removed, the display is ready to be removed and the inverter is accessible.
8 andere personen hebben deze handleiding voltooid.
3 opmerkingen
For every step we need to have an action. Step 4 of dissasembling the screen does not have this.
In step 5 we remove the inverter cable, but in step 6 we say inverter cable... again . Is this true?
It should say Status LED, not inverter.
Very informative, just fished following this guide. my replacement LCD came with the bracket that is normally attached to the bezel, so i had one extra (no brainer) step
