Ga door naar hoofdinhoud
Inleiding
Remove bottom housing to reveal the inside of the iMac.
Onderdelen
Geen onderdelen opgegeven.
  1. Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. Loosen the four Phillips #0 screws.
    • Loosen the four Phillips #0 screws.
  3. Carefully remove the base access panel.
    • Carefully remove the base access panel.
  4. Remove the four 25mm T-15 screws. Remove the four 25mm T-15 screws.
    • Remove the four 25mm T-15 screws.
  5. Open the housing plate. Be gentle with the wires still connected to the logic board  so as not to ruin the cables.
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Justin
292 Reputatie
3 handleidingen geschreven
Cal Poly, Team 21-22, Maness Fall 2011 Lid van Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 Leden
13 handleidingen geschreven
Één commentaar
If you do this - don't you still need to apply a fresh coat of thermal paste to the exposed ends of the two heat-sink posts (that separate when you open a G4 flatpanel this far) - my understanding was that the machine would overheat and you'd be left with didley squat!!
Gregg :O)
amicuset - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,870
