Ga door naar hoofdinhoud
iMac G4 17 800 MHz EMC 1936 Battery Replacement
Wat je nodig hebt
  1. iMac G4 17 800 MHz EMC 1936 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 iMac G4 17 800 MHz EMC 1936 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 iMac G4 17 800 MHz EMC 1936 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • G4 bottom Plate with four captive Phillips screws
    • The bottom of the plate will list the serial number, MHz of the machine, standard RAM and hard drive size
  2. iMac G4 17 800 MHz EMC 1936 Battery Replacement: stap 2, afbeelding 1 van 1
    • Here the plate has been removed exposing the slot for the Airport Card and User added RAM slot.
  3. iMac G4 17 800 MHz EMC 1936 Battery Replacement: stap 3, afbeelding 1 van 2 iMac G4 17 800 MHz EMC 1936 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the four T15 torx screws.
    • Set the unit on it's base, grasp the neck and tilt it to separate the base.
  4. iMac G4 17 800 MHz EMC 1936 Battery Replacement: stap 4, afbeelding 1 van 2 iMac G4 17 800 MHz EMC 1936 Battery Replacement: stap 4, afbeelding 2 van 2
    • The IDE cable unplugs first.
    • Locate the 3.6 volt 1/2 AA Lithium PRAM battery on the logic board and replace it.
Conclusie
10 andere personen hebben deze handleiding voltooid.
mayer
686.177 Reputatie
12 handleidingen geschreven
MacHale Enterprises Lid van MacHale Enterprises
Business
1 Lid
20 handleidingen geschreven
2 opmerkingen
These directions do not explain how to do any step of the process particularly showing where the battery is and how to carefully remove the bottom plate without breaking the logic board connector or cables. Also they are redundant as there are already directions to replace the PRAM Battery on this site. There is no point in there being two sets of directions for the same fix.
Sheldon Buchler - Antwoord
Sad that none of the pictures actually show the battery! Look for the other iMac G4 battery guide its better, although it misses the step of recoating the heat sinks with thermal paste.
Netmammal - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 38
Altijd: 15,400
