Ga door naar hoofdinhoud
iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement
Wat je nodig hebt
  1. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, Outer Base Plate: stap 1, afbeelding 1 van 2 iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, Outer Base Plate: stap 1, afbeelding 2 van 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement: stap 2, afbeelding 1 van 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, RAM DIMM: stap 3, afbeelding 1 van 2 iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, RAM DIMM: stap 3, afbeelding 2 van 2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
    You to not need to remove the RAM to complete this task.
    douglux - Antwoord
Conclusie
10 andere personen hebben deze handleiding voltooid.
Ryan Kozak
1.675 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-32, Amido Fall 2011 Lid van Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Leden
8 handleidingen geschreven
2 opmerkingen
Please correct the title, this is a 144 pin SODIMM, it is not a DIMM
The 168 pin DIMM is used in the internal socket.
Canadaram - Antwoord
Thanks For catching this Typo! :-)
Ben Capehart -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 5,723
