Inleiding
The iMac uses an incredibly hard to get to power supply. It has 24-Pins. This will require taking the iMac fully apart.
Wat je nodig hebt
The iMac G3. This was a great computer for the time, and had plenty of features.
Removing the front bezel:
There isn't a great position to put the iMac in to remove the front bezel. I recommend flipping it so it it like it would normally be positioned.
Remove these two Phillips screws.
Now, work your way around the bezel with a flathead screwdriver, and then, pivot it up towards the top, and remove it.
Now, swing the board out, and remove the following connectors:
AC Power
To System Fan
Don't remove this. It comes free with the logic board power.
To Display Driver
The connector that is attatched to the logic board; to remove it, simply thread it through the hole in the metal:
Now, you should be able to remove the power supply.
6 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
i have exactly this problem with my vintage imac g3 took it to repair shop they said could not find it do you know where i can get this power supply and pay to have it installed
