Ga door naar hoofdinhoud
iMac 27" Mid-2011 Broken Display Power Connector Pins Replacement
Wat je nodig hebt
  1. iMac 27" Mid-2011 Broken Display Power Connector Pins Replacement, Locate broken pin: stap 1, afbeelding 1 van 2 iMac 27" Mid-2011 Broken Display Power Connector Pins Replacement, Locate broken pin: stap 1, afbeelding 2 van 2
    • This can be a connector within the iMac or another board for parts. I found an unused connector in my computer.
  2. Gereedschap gebruikt in deze stap:
    • Apply the soldering iron to the base of the broken pin connected to the circuit board while levering the tweezers behind it pulling it out slowly.
    • Same as previous step.
    • Slide the pin in the desired connector until it is firmly seated inside.
    • Apply pressure to the base of the pin with the tweezers and solder the pin back in place.
Eindstreep
Mathew Mulligan
143 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 59
Altijd: 6,136
