Inleiding
Prerequisite-only guide to replace the logic board assembly in an iMac 27" 2017.
Wat je nodig hebt
Use a T5 Torx screwdriver to remove the two 4 mm screws securing the AirPort/Bluetooth antenna cables.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use the tip of a spudger to flip open the retaining flap on the microphone ribbon cable ZIF socket.
Use tweezers to gently pull the microphone ribbon cable straight out of its socket.
Bijna klaar!
Conclusie
