Ga door naar hoofdinhoud
iLive IKBC384S Motherboard Replacement
Wat je nodig hebt
  1. iLive IKBC384S Motherboard Replacement, Top Cover: stap 1, afbeelding 1 van 2 iLive IKBC384S Motherboard Replacement, Top Cover: stap 1, afbeelding 2 van 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Motherboard Replacement: stap 2, afbeelding 1 van 2 iLive IKBC384S Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Motherboard Replacement: stap 3, afbeelding 1 van 2 iLive IKBC384S Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 1
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  5. iLive IKBC384S Motherboard Replacement: stap 5, afbeelding 1 van 2 iLive IKBC384S Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Disconnect the two power connectors from the motherboard.
  6. iLive IKBC384S Motherboard Replacement: stap 6, afbeelding 1 van 1
    • You will need to desolder the antenna.
    • Be sure to desolder the piece connected to the motherboard not the wire.
  7. iLive IKBC384S Motherboard Replacement: stap 7, afbeelding 1 van 1
    • You will need to remove the speakers and power connector.
    • Once you have removed all of these from the motherboard, the motherboard can be removed
Conclusie
Tracy Walts
201 Reputatie
2 handleidingen geschreven
Texas Tech, Team S46-G6, Bennett Spring 2017 Lid van Texas Tech, Team S46-G6, Bennett Spring 2017
TTU-BENNETT-S17S46G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 268
