Ga door naar hoofdinhoud
Inleiding
This guide instructs you to replace the screen in an iHome iPL8. The process includes using two sizes of screwdrivers.
Onderdelen
Geen onderdelen opgegeven.
  1. Turn the device over to access the bottom panel.
    • Turn the device over to access the bottom panel.
    • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
  2. Using a Phillips #2 screwdriver, unscrew the captive screw.
    • Using a Phillips #2 screwdriver, unscrew the captive screw.
    • Keep turning until the screw and the door are loose.
  3. Lift and remove the battery access panel.
    • Lift and remove the battery access panel.
    • The captive screw will remain attached to the panel.
  4. Gently press on the rim of the 3V battery. Remove the 3V battery.
    • Gently press on the rim of the 3V battery.
    • Remove the 3V battery.
  5. Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
    • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
    • Remove the four 6mm Phillips #2 screws.
  6. Remove the four round pads from the bottom of the device.
    • Remove the four round pads from the bottom of the device.
    • There are two additional 6mm Phillips #2 screws under the pads.
    • Using a Phillips #2 screwdriver, remove the two remaining screws.
    • Put your hand on the silver bottom case and gently pull it outward.
  7. Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners. Pull out the green circuit board on the two corners.
    • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
    • Pull out the green circuit board on the two corners.
    • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
  8. Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device. Remove the two screws and the black cover.
    • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
    • Remove the two screws and the black cover.
    • Gently remove the lightning dock assembly.
    • The lightning dock assembly is connected to wires.
  9. Remove the two 2.5mm screws using a Phillips #1 screwdriver. Remove the back cover. Use your fingers to reposition the lightning connector.
    • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
    • Remove the back cover.
    • Use your fingers to reposition the lightning connector.
    • Make sure ALL of the lightning connector is exposed.
  10. Look at the side of the device. You will see a green panel connecting to the black box by a white stripe.
    • Look at the side of the device. You will see a green panel connecting to the black box by a white stripe.
    • Remove the four 2.5 mm Phillips #1 screws on the green panel.
    • Flip the green panel to reveal the front of the screen.
  11. Locate the transparent, rectangular plastic screen cover. Gently lift the cover off.
    • Locate the transparent, rectangular plastic screen cover.
    • Gently lift the cover off.
    • The screen is now revealed. Replace the screen with a functioning one.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Chen Zhong
569 Reputatie
4 handleidingen geschreven
UC Davis, Team S18-G5, Lore Winter 2019 Lid van UC Davis, Team S18-G5, Lore Winter 2019
UCD-LORE-W19S18G5
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 113
