Wat je nodig hebt
Remove the two 8mm Phillips #0 screws from the iHome's iPod adapter.
Use the metal spudger to loosen the edges of the plastic cover.
Pull the adapter up and away from the housing, rotating it forward slightly as you lift it so the top faces you.
Remove the four 7mm Phillips #00 screws attaching the black plastic cover to the bottom of the adapter assembly.
Bijna klaar!
Conclusie
