1. Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws. Unscrew the four 11mm screws from the base. Pry the base loose using the spudger.
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. Remove the two black 6mm screws connecting the main circuit board to the housing top. Grasp front housing and back housing firmly.
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Grasp front housing and back housing firmly.
    • Gently pull front housing from the back housing.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
    • Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
  5. Lift speaker assembly Remove four 7mm screws to detach speaker from speaker assembly
    • Lift speaker assembly
    • Remove four 7mm screws to detach speaker from speaker assembly
Conclusie
Brandy
601 Reputatie
6 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 129
