Ga door naar hoofdinhoud
iHome iP21 Motherboard Replacement
Wat je nodig hebt
  1. iHome iP21 Motherboard Replacement, Base: stap 1, afbeelding 1 van 3 iHome iP21 Motherboard Replacement, Base: stap 1, afbeelding 2 van 3 iHome iP21 Motherboard Replacement, Base: stap 1, afbeelding 3 van 3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Motherboard Replacement, Housing: stap 2, afbeelding 1 van 2 iHome iP21 Motherboard Replacement, Housing: stap 2, afbeelding 2 van 2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Motherboard Replacement, Circuit board: stap 3, afbeelding 1 van 1
    • Follow the prerequisite guide to remove the main housing.
  4. iHome iP21 Motherboard Replacement, Circuit board mount: stap 4, afbeelding 1 van 1
    • Remove the two 7mm screws from the circuit board
  5. iHome iP21 Motherboard Replacement, Mounting Bracket: stap 5, afbeelding 1 van 1
    • Remove the three 6mm screws to detach the circuit board from metal mounting bracket.
  6. iHome iP21 Motherboard Replacement, Cables: stap 6, afbeelding 1 van 3 iHome iP21 Motherboard Replacement, Cables: stap 6, afbeelding 2 van 3 iHome iP21 Motherboard Replacement, Cables: stap 6, afbeelding 3 van 3
    • Peel the glue from each of the three ribbon cable connections.
    • Remove the solder joints from the back of each ribbon cable.
    • Remove the ground wires by removing the solder joints on the back of the housing.
  7. iHome iP21 Motherboard Replacement, Detach cables from circuit board: stap 7, afbeelding 1 van 3 iHome iP21 Motherboard Replacement, Detach cables from circuit board: stap 7, afbeelding 2 van 3 iHome iP21 Motherboard Replacement, Detach cables from circuit board: stap 7, afbeelding 3 van 3
    • Remove glue from 3 ribbon cables from circuit board using fingers
    • Detach speaker cables from circuit board with soldering iron
    • Remove 3 ribbon cables with soldering iron
Conclusie
Brandy
601 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 270
