Ga door naar hoofdinhoud
iHome iP1 30-pin Connector Replacement
Wat je nodig hebt
  1. iHome iP1 30-pin Connector Replacement, Dock Cover: stap 1, afbeelding 1 van 1
    • Orient the iHome upside down with the speakers facing you.
  2. iHome iP1 30-pin Connector Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 9.5 mm Phillips #1 screws from the dock cover.
  3. iHome iP1 30-pin Connector Replacement: stap 3, afbeelding 1 van 3 iHome iP1 30-pin Connector Replacement: stap 3, afbeelding 2 van 3 iHome iP1 30-pin Connector Replacement: stap 3, afbeelding 3 van 3
    • Remove the dock cover by grabbing its sides and pulling it up and away from the faceplate.
    Where can I buy this part
    Soude Alibabaie - Antwoord
  4. iHome iP1 30-pin Connector Replacement, Back Cover: stap 4, afbeelding 1 van 1
    • Orient the iHome upside down with the speakers facing away from you.
    necesito toda la placa madre o el diagrama para pedir una peque;a pieza que se quemo
    Teodoro De la o - Antwoord
  5. iHome iP1 30-pin Connector Replacement: stap 5, afbeelding 1 van 2 iHome iP1 30-pin Connector Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
  6. iHome iP1 30-pin Connector Replacement: stap 6, afbeelding 1 van 1
    • Remove the back cover by grabbing its sides and lifting it off the iHome.
  7. iHome iP1 30-pin Connector Replacement, 30-pin Connector: stap 7, afbeelding 1 van 1
    • Rotate the iHome so that the speakers are facing you.
    • Disconnect the silver ribbon cable connected to the 30-pin connector (the middle one) by pulling it directly up.
  8. iHome iP1 30-pin Connector Replacement: stap 8, afbeelding 1 van 3 iHome iP1 30-pin Connector Replacement: stap 8, afbeelding 2 van 3 iHome iP1 30-pin Connector Replacement: stap 8, afbeelding 3 van 3
    • Rotate the iHome so that the speakers are once again facing away from you and the motherboard is still exposed.
    • Unplug the wide red/white/black wire bundle from the lower right-hand corner of the motherboard by pulling it out of their connection.
    hi,
    can i get new Board for this Device.
    kindly reply to riyupc123@gmail.com
    Riyu PC - Antwoord
  9. iHome iP1 30-pin Connector Replacement: stap 9, afbeelding 1 van 3 iHome iP1 30-pin Connector Replacement: stap 9, afbeelding 2 van 3 iHome iP1 30-pin Connector Replacement: stap 9, afbeelding 3 van 3
    • Rotate the iHome iP1 so that the speakers are now facing you.
    • Remove both of the speaker covers by pulling them off of the faceplate.
  10. iHome iP1 30-pin Connector Replacement: stap 10, afbeelding 1 van 1
    • Unscrew the twelve 14.5 mm Phillips #2 screws holding the faceplate to the speaker housing. (There are six screws connecting the faceplate to each speaker.)
    • Completing this step will loosen the faceplate enough to pull the bundle of cables attached to the 30-pin connector through a hole in the faceplate, allowing the 30-pin connector to be removed from the iHome.
  11. iHome iP1 30-pin Connector Replacement: stap 11, afbeelding 1 van 3 iHome iP1 30-pin Connector Replacement: stap 11, afbeelding 2 van 3 iHome iP1 30-pin Connector Replacement: stap 11, afbeelding 3 van 3
    • Detach the 30-pin connector from the dock housing by pushing it through the slot which it sticks out of.
    • Sometimes the 30-pin connector can get stuck in the dock housing, making it difficult to push through. To prevent this, push each side of the 30-pin connector evenly. This step can be accomplished without the use of any additional tools.
    • The command buttons have been shown as removed to show how to detach the 30-pin connector. However, it is not necessary to remove the command buttons in order to remove the 30-pin connector.
  12. iHome iP1 30-pin Connector Replacement: stap 12, afbeelding 1 van 3 iHome iP1 30-pin Connector Replacement: stap 12, afbeelding 2 van 3 iHome iP1 30-pin Connector Replacement: stap 12, afbeelding 3 van 3
    • Remove the 30-pin connector from the iHome by pulling the bundle of cables attached to it through the center hole in the faceplate.
    • You may have to wiggle the faceplate to be able to pull the bundle of cables through its center hole.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Wen Sullivan
518 Reputatie
4 handleidingen geschreven
Cal Poly, Team 20-1, Livingston Fall 2016 Lid van Cal Poly, Team 20-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G1
4 Leden
7 handleidingen geschreven
4 opmerkingen
Where can you buy a new pin connector?
shoreman19 - Antwoord
Where can I buy a new pin connector?
Edward Voermans - Antwoord
where can i buy new Board
Riyu PC - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 2,464
