Inleiding
Use this guide to replace your iHome iP1's damaged or faulty 30-pin connector. This connector is located on the iPod/iPhone dock and is used to connect your Apple device to your iHome iP1.
Wat je nodig hebt
Remove the dock cover by grabbing its sides and pulling it up and away from the faceplate.
Orient the iHome upside down with the speakers facing away from you.
necesito toda la placa madre o el diagrama para pedir una peque;a pieza que se quemo
Rotate the iHome so that the speakers are facing you.
Disconnect the silver ribbon cable connected to the 30-pin connector (the middle one) by pulling it directly up.
Rotate the iHome so that the speakers are once again facing away from you and the motherboard is still exposed.
Unplug the wide red/white/black wire bundle from the lower right-hand corner of the motherboard by pulling it out of their connection.
Één andere persoon heeft deze handleiding voltooid.
4 opmerkingen
Where can you buy a new pin connector?
Where can I buy a new pin connector?
