Ga door naar hoofdinhoud
iHome iH8BR Lower Case Replacement
Wat je nodig hebt
  1. iHome iH8BR Lower Case Replacement, Lower Case: stap 1, afbeelding 1 van 3 iHome iH8BR Lower Case Replacement, Lower Case: stap 1, afbeelding 2 van 3 iHome iH8BR Lower Case Replacement, Lower Case: stap 1, afbeelding 3 van 3
    • Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
    • Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
    • Remove the battery cover and the batteries.
  2. iHome iH8BR Lower Case Replacement: stap 2, afbeelding 1 van 2 iHome iH8BR Lower Case Replacement: stap 2, afbeelding 2 van 2
    • Slide a spudger under the two front rubber pads to expose two hidden screws.
  3. iHome iH8BR Lower Case Replacement: stap 3, afbeelding 1 van 1
    • Remove the following eight screws:
    • Four 15.1 mm Phillips #2 screws near the front of the device.
    • Four 12.7 mm Phillips #2 screws near the back of the device.
    • The slots for the four 12.7 mm screws are very narrow, so you will need a slender, Phillips #2 screwdriver that does not feature replaceable heads in order to reach them.
  4. iHome iH8BR Lower Case Replacement: stap 4, afbeelding 1 van 2 iHome iH8BR Lower Case Replacement: stap 4, afbeelding 2 van 2
    • Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
    • Be careful and do not yank the bottom case. A white ribbon wire is the only thing that connects the bottom case to the rest of the device.
    • Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
    • The lower case can now be completely removed from the device!
Conclusie
cfredric
19 Reputatie
6 handleidingen geschreven
Cal Poly, Team 12-33, Amido Spring 2013 Lid van Cal Poly, Team 12-33, Amido Spring 2013
CPSU-AMIDO-S13S12G33
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 505
