Inleiding
The iHome dock found at the top of the device is unresponsive when connected to an iPod/iPhone. The iHome dock may also be bent or broken and will need to be replaced in order to connect an iPod/iPhone.
Wat je nodig hebt
Locate all screws on the back of the iHome. Each screw can be located by the arrows on the iHome.
Two Countersunk 9.7 mm Phillips #2 screws in the middle.
Two 15.9 mm Phillips #2 screws.
Six 13.9 mm Phillips #2 screws.
Some screws are located under the black sticky pads. Gently remove the black sticky pads and it will expose the screws.
Two 11.8 mm Phillips #2 screws.
Disconnect the final connector pin series and carefully set your lid behind the body of the iHome.
The tiny speaker will not be disconnected for this repair, but you can easily remove it from the lid by means of a paperclip from the outside. While not necessary, this can help prevent damage to your device.
Remove the four screws from the mounting bracket.
Two 11.7 mm Phillips #2 screws.
Two 12 mm Phillips #2 screws with metal washers attached to them.
Één andere persoon heeft deze handleiding voltooid.
