Ga door naar hoofdinhoud
iHome iH27B iPod Adapter Replacement
Wat je nodig hebt
  1. iHome iH27B iPod Adapter Replacement, Adapter: stap 1, afbeelding 1 van 1
    • Set the IHome on a surface facing upward.
    • Locate the two screws on the docking station adapter.
    • Remove the following screws:
    • Two 10 mm Phillips #0
  2. iHome iH27B iPod Adapter Replacement: stap 2, afbeelding 1 van 1
    • Grip the plastic adapter case and pull upwards with a medium amount of force. You will have to twist forward a little so that the connections are visible.
    • The adapter will still be connected with wires, so make sure not to pull too hard.
  3. iHome iH27B iPod Adapter Replacement: stap 3, afbeelding 1 van 3 iHome iH27B iPod Adapter Replacement: stap 3, afbeelding 2 van 3 iHome iH27B iPod Adapter Replacement: stap 3, afbeelding 3 van 3
    • Four 7 mm Phillips #0
    • Lift up the two black plastic pieces that have come loose on either side of the circuit board, and set them aside.
  4. iHome iH27B iPod Adapter Replacement: stap 4, afbeelding 1 van 2 iHome iH27B iPod Adapter Replacement: stap 4, afbeelding 2 van 2
    • Carefully pry apart the bundle of white wires connected at the junction with the plastic opening tool.
    • Do this slowly. Be careful not to damage the wires
    • Lift up the circuit board that has become loose.
  5. iHome iH27B iPod Adapter Replacement: stap 5, afbeelding 1 van 1
    • Pull out the adapter, and replace it with the new one.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
John Kraemer
76 Reputatie
9 handleidingen geschreven
Cal Poly, Team 3-21, Amido Fall 2012 Lid van Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,324
