Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Remove any iPod or apple music device connected to the iHome and unplug from any power source.
Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
Remove the plastic slide from its location and set it aside.
Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
Set the batteries aside, careful to not get them wet.
Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
Apply force in the direction of the arrow shown above the word "Open" on the plastic. The plastic piece covering the watch battery should come loose.
Set this plastic covering aside as well.
Remove the following screws:
Two 10 mm Phillips #0
Pull the speakers away and set them aside for now. They should still be connected to the rest of the iHome by two wires.
Carefully lift the main motherboard out of the way of the button control circuit board.
Four 6 mm Phillips head screws
Één andere persoon heeft deze handleiding voltooid.
Één commentaar
My volume decrease button was not working. I disassembled per these instructions, blew out the device with compressed air and then contact cleaner and reassembled per the reverse instructions. The screws in step 9 were slightly different (the same holes were there, but the presence/absence of screws was slightly different). I am now happily listening to my iHome right now. Thank you for posting this!!!
