Ga door naar hoofdinhoud
iHome iH27B Main Motherboard Replacement
Wat je nodig hebt
  1. iHome iH27B Main Motherboard Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. iHome iH27B Main Motherboard Replacement: stap 2, afbeelding 1 van 3 iHome iH27B Main Motherboard Replacement: stap 2, afbeelding 2 van 3 iHome iH27B Main Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Set the plastic covering and the watch battery aside.
  3. iHome iH27B Main Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the following screws:
    • Eight 10 mm using the Phillips #0 on the bottom of your device.
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. iHome iH27B Main Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  5. iHome iH27B Main Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
  6. iHome iH27B Main Motherboard Replacement, AV circuit board: stap 6, afbeelding 1 van 1
    • Two 10 mm Phillips #0
  7. iHome iH27B Main Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
  8. iHome iH27B Main Motherboard Replacement, Main Motherboard: stap 8, afbeelding 1 van 1
    • Pull the speakers away and set them aside for now. They should still be connected to the rest of the iHome by two wires.
  9. iHome iH27B Main Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the following 6 screws:
    • Two 7 mm Phillips #0
    • Three 10 mm Phillips #2
    • One 9 mm Phillips #2
    • Set the screws aside, careful to not mix them up with your other screws.
Conclusie
John Kraemer
76 Reputatie
9 handleidingen geschreven
Cal Poly, Team 3-21, Amido Fall 2012 Lid van Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 861
