Ga door naar hoofdinhoud
iHome iH27B AV circuit board Replacement
Wat je nodig hebt
  1. iHome iH27B AV circuit board Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. iHome iH27B AV circuit board Replacement: stap 2, afbeelding 1 van 3 iHome iH27B AV circuit board Replacement: stap 2, afbeelding 2 van 3 iHome iH27B AV circuit board Replacement: stap 2, afbeelding 3 van 3
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Set the plastic covering and the watch battery aside.
  3. iHome iH27B AV circuit board Replacement: stap 3, afbeelding 1 van 1
    • Remove the following screws:
    • Eight 10 mm using the Phillips #0 on the bottom of your device.
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. iHome iH27B AV circuit board Replacement: stap 4, afbeelding 1 van 1
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  5. iHome iH27B AV circuit board Replacement: stap 5, afbeelding 1 van 1
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
  6. iHome iH27B AV circuit board Replacement, AV circuit board: stap 6, afbeelding 1 van 1
    • Remove the two 10 mm Phillips #0 screws attaching the circuit board to the case.
  7. iHome iH27B AV circuit board Replacement: stap 7, afbeelding 1 van 1
    • Desolder each of the sets of grey wires as close as you can to the circuit board.
    • Retrieve your replacement board, making sure to align it the same way as your defective board was previously aligned.
    • Solder the ends of the grey wires to the same locations on the replacement motherboard as you had them on your original board. (Not pictured in this guide.)
Conclusie
John Kraemer
76 Reputatie
9 handleidingen geschreven
Cal Poly, Team 3-21, Amido Fall 2012 Lid van Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 1,736
