Ga door naar hoofdinhoud
iHome iBT84 Motherboard Replacement
Wat je nodig hebt
  1. iHome iBT84 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 iHome iBT84 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • On the opposite side of the speaker should be a sticker, remove it with your fingers or the flat plastic iFIxit tool.
    • Use a Philip's screwdriver to take the screws out of the cover.
  2. iHome iBT84 Motherboard Replacement: stap 2, afbeelding 1 van 2 iHome iBT84 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Once the screws are all out, the cover should come off revealing the motherboard.
  3. iHome iBT84 Motherboard Replacement: stap 3, afbeelding 1 van 3 iHome iBT84 Motherboard Replacement: stap 3, afbeelding 2 van 3 iHome iBT84 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • You will notice that the triangular black volume piece is loose, make sure to take that off revealing the buttons.
    • Once that is done, the motherboard can be taken out. May require some wiggling.
    • Make sure none of the wires are damaged and that they are all connected.
  4. iHome iBT84 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • The connections shown here can be taken off by pulling on the white plastic connector piece.
    • The same can be said about the white, paper like, connectors. Pull on them gently.
    • Once all connections are apart, the motherboard is safe to be replaced.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 987
