Ga door naar hoofdinhoud
iHome iBT16 Base Plate Replacement
Wat je nodig hebt
  1. iHome iBT16 Base Plate Replacement, Base Plate: stap 1, afbeelding 1 van 2 iHome iBT16 Base Plate Replacement, Base Plate: stap 1, afbeelding 2 van 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Base Plate Replacement: stap 2, afbeelding 1 van 2 iHome iBT16 Base Plate Replacement: stap 2, afbeelding 2 van 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
Conclusie
Ryan Edwards
331 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 Lid van UMass Dartmouth, Team S3-G6, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G6
2 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 16
Altijd: 229
