Ga door naar hoofdinhoud
iHome iAVS16 LCD (Display) Replacement
Wat je nodig hebt
  1. iHome iAVS16 LCD (Display) Replacement, Power Board: stap 1, afbeelding 1 van 3 iHome iAVS16 LCD (Display) Replacement, Power Board: stap 1, afbeelding 2 van 3 iHome iAVS16 LCD (Display) Replacement, Power Board: stap 1, afbeelding 3 van 3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 LCD (Display) Replacement: stap 2, afbeelding 1 van 3 iHome iAVS16 LCD (Display) Replacement: stap 2, afbeelding 2 van 3 iHome iAVS16 LCD (Display) Replacement: stap 2, afbeelding 3 van 3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 LCD (Display) Replacement: stap 3, afbeelding 1 van 2 iHome iAVS16 LCD (Display) Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 LCD (Display) Replacement: stap 4, afbeelding 1 van 3 iHome iAVS16 LCD (Display) Replacement: stap 4, afbeelding 2 van 3 iHome iAVS16 LCD (Display) Replacement: stap 4, afbeelding 3 van 3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 LCD (Display) Replacement, LCD (Display): stap 5, afbeelding 1 van 3 iHome iAVS16 LCD (Display) Replacement, LCD (Display): stap 5, afbeelding 2 van 3 iHome iAVS16 LCD (Display) Replacement, LCD (Display): stap 5, afbeelding 3 van 3
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 LCD (Display) Replacement: stap 6, afbeelding 1 van 1
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 LCD (Display) Replacement: stap 7, afbeelding 1 van 3 iHome iAVS16 LCD (Display) Replacement: stap 7, afbeelding 2 van 3 iHome iAVS16 LCD (Display) Replacement: stap 7, afbeelding 3 van 3
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
Conclusie
Marco Sousa
293 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 Lid van UMass Dartmouth, Team S1-G7, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G7
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 187
