Ga door naar hoofdinhoud
Inleiding
This will show you how to install a new speaker into your iHome. For help troubleshooting click the link to our troubleshooting page iHome IH11 Troubleshooting.
Onderdelen
Geen onderdelen opgegeven.
  1. Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. Remove the two 9.0mm screws on the back of the iHome with a Phillips #1 screwdriver. Repeat the previous step for the two 9.0mm screws on the bottom.
    • Remove the two 9.0mm screws on the back of the iHome with a Phillips #1 screwdriver.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. Remove the two 12.0mm screws holding the speaker to the iHome with a Phillips #1 screwdriver.
    • Remove the two 12.0mm screws holding the speaker to the iHome with a Phillips #1 screwdriver.
  4. Remove the four 12.0mm screws on the face of the speaker with the Phillips #1 Screwdriver. Carefully lift speaker out of its casing.
    • Remove the four 12.0mm screws on the face of the speaker with the Phillips #1 Screwdriver.
    • Carefully lift speaker out of its casing.
  5. Unsolder the two wires that connect to the speaker.
    • Unsolder the two wires that connect to the speaker.
Conclusie
Courtney Steinberg
35 Reputatie
3 handleidingen geschreven
Cal Poly, Team 14-9, Maness Spring 2013 Lid van Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Leden
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 311
