Inleiding
This guide will describe how to replace the speaker system's iPod/iPhone input.
Wat je nodig hebt
Use your fingers to slide the battery case cover off in the direction of the arrows.
Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
Gereedschap gebruikt in deze stap:Tweezers$4.99
Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
Unscrew the 0.6 mm screw located in the center of the battery case.
Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
Remove the back cover carefully; there are many wires that connect it to the device.
Gently remove the Line In chip with tweezers.
Note: The Line In chip is located on the left side of the device.
Use scissors to cut the black, yellow, and red wires that connect the Line In chip to the iPod/iPhone input.
Remove the old iPod/iPhone input and its associated wires.
Gereedschap gebruikt in deze stap:Desoldering Pump$3.99
Place new iPod/iPhone input wires, one by one, in their previous position on the Line In chip. Wrap a strip of soldering wire on the point of contact between the chip and input wire.
Use tweezers to carefully place the newly soldered Line In chip back into its original position.
With tweezers, insert the end of the iPod/iPhone input through its designated hole.
With both thumbs, push in the black plastic input stand until it snaps into place.
