Ga door naar hoofdinhoud
Wat je nodig hebt
  1. iHip Fold-up Portable Speaker LINE IN ADAPTER Replacement, Removing the battery case cover: stap 1, afbeelding 1 van 1
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-up Portable Speaker LINE IN ADAPTER Replacement, Cleaning the battery case: stap 2, afbeelding 1 van 3 iHip Fold-up Portable Speaker LINE IN ADAPTER Replacement, Cleaning the battery case: stap 2, afbeelding 2 van 3 iHip Fold-up Portable Speaker LINE IN ADAPTER Replacement, Cleaning the battery case: stap 2, afbeelding 3 van 3
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-up Portable Speaker LINE IN ADAPTER Replacement, Removing the screws: stap 3, afbeelding 1 van 2 iHip Fold-up Portable Speaker LINE IN ADAPTER Replacement, Removing the screws: stap 3, afbeelding 2 van 2
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-up Portable Speaker LINE IN ADAPTER Replacement, Removing the back cover: stap 4, afbeelding 1 van 2 iHip Fold-up Portable Speaker LINE IN ADAPTER Replacement, Removing the back cover: stap 4, afbeelding 2 van 2
    • Remove the back cover carefully; there are many wires that connect it to the device.
  5. iHip Fold-up Portable Speaker LINE IN ADAPTER Replacement, Locating the LINE IN Adapter: stap 5, afbeelding 1 van 2 iHip Fold-up Portable Speaker LINE IN ADAPTER Replacement, Locating the LINE IN Adapter: stap 5, afbeelding 2 van 2
    • Position the portable speaker device so that the back cover and the speaker are both laying flat, giving you access to the inside of the device
    • If the motherboard is at the bottom when you are looking down at the device, the LINE IN adapter should be on the left side of the back cover
    • Carefully remove the LINE IN adapter using a pair of tweezers
  6. iHip Fold-up Portable Speaker LINE IN ADAPTER Replacement, Removing the Adapter: stap 6, afbeelding 1 van 1
    • Remove the black and red wires attached to the LINE IN adapter that extend from the motherboard by cutting them with scissors
    • Repeat previous step for the blue and second black wire connecting the adapter to the battery case.
    • At this point, you should be able to carefully remove the entire faulty adapter and the wires.
  7. iHip Fold-up Portable Speaker LINE IN ADAPTER Replacement, Assembling the New Adapter: stap 7, afbeelding 1 van 1
    • Position the newly purchased LINE IN adapter and wires in place
    • Using a soldering iron and soldering wire, reattach the red and black wires that extend from the motherboard to their original position on the LINE IN adapter
    • Use the soldering iron and soldering wire again to reattach the black and blue wires that extend from the battery case to their original position on the LINE IN adapter
    • The blue wire should attach on the bottom of the battery case and the black wire on the top insertion.
    • The new LINE IN adapter should now be properly assembled in place with the wires connected to their proper location.
Conclusie
Amanda
201 Reputatie
2 handleidingen geschreven
Clemson, Team 3-4, Benson Fall 2014 Lid van Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 445
