Ga door naar hoofdinhoud
iHealth Edge Motherboard Replacement
Wat je nodig hebt
  1. iHealth Edge Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Lightly heat device with hair dryer for 15 seconds to soften adhesive.
    Vraag FixBot
    Voeg opmerking toe
  2. iHealth Edge Motherboard Replacement: stap 2, afbeelding 1 van 1
    • After heating adhesive, firmly pry apart the two halves.
    Vraag FixBot
    Voeg opmerking toe
  3. iHealth Edge Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove polymer cover that is protecting the mother board, it should just come out when two halves are separated.
    Vraag FixBot
    Voeg opmerking toe
  4. iHealth Edge Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use a pair of nylon spudgers to assist the removal of the motherboard. Pry up on two tabs and the mother board will pop out.
    Vraag FixBot
    Voeg opmerking toe
  5. iHealth Edge Motherboard Replacement: stap 5, afbeelding 1 van 1
    • This shows the mother board out and exposed.
    Vraag FixBot
    Voeg opmerking toe
  6. iHealth Edge Motherboard Replacement: stap 6, afbeelding 1 van 1
    • You must remove the solder from two wires from the motherboard that are connected to the battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Gabrielle Bettegnies
349 Reputatie
3 handleidingen geschreven
IUPUI, Team S1-G4, Freund Fall 2017 Lid van IUPUI, Team S1-G4, Freund Fall 2017
IUPUI-FREUND-F17S1G4
4 Leden
2Gids Commentaar
This guide will help show you how to replace the mother board on the iHealth Edge. You must take the device and remove the two piece that are stuck together using a blow dryer. This will expose the inside of the device to see screen. This is where we will begin to learn how to replace the motherboard.
Remove the word help in the first sentence. The guide will show you how to replace the mother board.
Following is a partial description of what needs to be on the device page. This is copied from the iFixit web site. I don’t think you’ve met these requirements.
-Includes thorough information describing the device and its background information to educate readers and aid them in identifying their device
-Lists at least three helpful, properly formatted links on the device page
Linda Freund - Antwoord Deel
On Motherboard replacement guide, the last step is not needed.
How many wires need to be desoldered? If its more than one, you should give the number. Example: Use a soldering iron to remove 2 wires.
Looks good. I’m impressed. Lets see what iFixit says.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 44
Altijd: 618
