Ga door naar hoofdinhoud
iHealth Edge Battery Replacement
Wat je nodig hebt
  1. iHealth Edge Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Lightly heat device with hair dryer for 15 seconds to soften adhesive.
    Vraag FixBot
    Voeg opmerking toe
  2. iHealth Edge Battery Replacement: stap 2, afbeelding 1 van 1
    • After heating adhesive, firmly pry apart the two halves.
    Vraag FixBot
    Voeg opmerking toe
  3. iHealth Edge Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove polymer cover that is protecting the mother board, it should just come out when two halves are separated.
    Vraag FixBot
    Voeg opmerking toe
  4. iHealth Edge Battery Replacement: stap 4, afbeelding 1 van 1
    • Use a spudger or plastic opening tool to assist the removal of the motherboard. Pry up on two tabs and the mother board will pop out.
    Vraag FixBot
    Voeg opmerking toe
  5. iHealth Edge Battery Replacement: stap 5, afbeelding 1 van 1
    • This shows the mother board and battery out and exposed.
    Vraag FixBot
    Voeg opmerking toe
  6. iHealth Edge Battery Replacement: stap 6, afbeelding 1 van 1
    • You must remove the solder from two wires from the motherboard that are connected to the battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Gabrielle Bettegnies
349 Reputatie
3 handleidingen geschreven
IUPUI, Team S1-G4, Freund Fall 2017 Lid van IUPUI, Team S1-G4, Freund Fall 2017
IUPUI-FREUND-F17S1G4
4 Leden
1Gids Commentaar
where can I buy the new battery?? or what are the characteristics of the battery?
Fafi Dau - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 44
Altijd: 1,717
