Ga door naar hoofdinhoud
iHealth Edge Band Replacement
  1. iHealth Edge Band Replacement, Band: stap 1, afbeelding 1 van 1
    • Pull the elastic band away from the device as shown. You will need to use one hand to support the device and pull the elastic band with the other at about a 45 degree angle.
    Vraag FixBot
    Voeg opmerking toe
  2. iHealth Edge Band Replacement: stap 2, afbeelding 1 van 1
    • Pull the elastic band away from the device, you should now have the device with no band as shown.
    Vraag FixBot
    Voeg opmerking toe
  3. iHealth Edge Band Replacement: stap 3, afbeelding 1 van 2 iHealth Edge Band Replacement: stap 3, afbeelding 2 van 2
    • Place the elastic band into the channel in the side of the device shown in the picture. The band will pull into the channel and lock into place.
    Vraag FixBot
    Voeg opmerking toe
  4. iHealth Edge Band Replacement: stap 4, afbeelding 1 van 1
    • After pulling the band into place the guide is now complete. Your iHealth Edge should be ready for use.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
This guide will show you how to replace the arm band.
Gabrielle Bettegnies
349 Reputatie
3 handleidingen geschreven
IUPUI, Team S1-G4, Freund Fall 2017 Lid van IUPUI, Team S1-G4, Freund Fall 2017
IUPUI-FREUND-F17S1G4
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 33
Altijd: 611
