Ga door naar hoofdinhoud
iFixit Side Stack Retail Display Assembly
  1. iFixit Side Stack Retail Display Assembly, Empty Box Components: stap 1, afbeelding 1 van 1
    • Box should include:
    • Set of screws/driver
    • Metal rods
    • Honeycomb Base/Feet
    • Main stand (back/sides)
    • Two large, one small foldable shelf insert
    • Two large, one small black rectangular insert
    • "You can fix it" panel and iFixit topper (not pictured)
  2. iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: stap 2, afbeelding 1 van 3 iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: stap 2, afbeelding 2 van 3 iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: stap 2, afbeelding 3 van 3
    • The three angled supports fit into the two rectangular supports.
    • Place the fully constructed honeycomb base into the display.
  3. iFixit Side Stack Retail Display Assembly, "You can fix it": stap 3, afbeelding 1 van 3 iFixit Side Stack Retail Display Assembly, "You can fix it": stap 3, afbeelding 2 van 3 iFixit Side Stack Retail Display Assembly, "You can fix it": stap 3, afbeelding 3 van 3
    • Fit “You can fix it” panel over front of honeycomb base
    • “You can fix it” panel sides fit INSIDE of base walls
    • Use screws to fasten
  4. iFixit Side Stack Retail Display Assembly, Build Shelf Insert: stap 4, afbeelding 1 van 3 iFixit Side Stack Retail Display Assembly, Build Shelf Insert: stap 4, afbeelding 2 van 3 iFixit Side Stack Retail Display Assembly, Build Shelf Insert: stap 4, afbeelding 3 van 3
    • Build bottom shelf, using one of two larger foldable shelves
    • Tabs fit together, fit side tabs along back, then fold over and secure
  5. iFixit Side Stack Retail Display Assembly, Install Metal Supports: stap 5, afbeelding 1 van 2 iFixit Side Stack Retail Display Assembly, Install Metal Supports: stap 5, afbeelding 2 van 2
    • Install two metal support for middle shelf
    • Metal rods fit into provided holes
  6. iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: stap 6, afbeelding 1 van 3 iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: stap 6, afbeelding 2 van 3 iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: stap 6, afbeelding 3 van 3
    • Fit bottom shelf into bottom shelf slots cut into back of display
    • Tabs go out the back and then back in towards the front
    • Lay black shelf insert into shelf
    • Fit screws together to hold shelf in place
    • Repeat for middle and top shelves
    • Top shelf and insert are smaller than bottom and middle shelves
  7. iFixit Side Stack Retail Display Assembly, Fold Sides into Honeycomb Base: stap 7, afbeelding 1 van 1
    • Like so.
    • (Go Angels!)
  8. iFixit Side Stack Retail Display Assembly, iFixt Header Sign: stap 8, afbeelding 1 van 2 iFixit Side Stack Retail Display Assembly, iFixt Header Sign: stap 8, afbeelding 2 van 2
    • Fold top section down to make holes match
    • Align iFixit sign and install using screws
Conclusie
Eric Essen
18.012 Reputatie
8 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.784 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 354
