Ga door naar hoofdinhoud
iDevices iGrill Probe Replacement
Wat je nodig hebt
  1. iDevices iGrill Probe Replacement, Probes: stap 1, afbeelding 1 van 1
    • Remove the back plastic cover from the device; this should allow you access to the batteries.
  2. iDevices iGrill Probe Replacement: stap 2, afbeelding 1 van 1
    • Remove the batteries from the device.
  3. iDevices iGrill Probe Replacement: stap 3, afbeelding 1 van 2 iDevices iGrill Probe Replacement: stap 3, afbeelding 2 van 2
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm screws using a Phillips screwdriver. The screws are located on the left side of the internal cover.
    • Remove the accompanying plastic tabs under the screws.
    • Gently pull off the back cover from the device.
  4. iDevices iGrill Probe Replacement: stap 4, afbeelding 1 van 3 iDevices iGrill Probe Replacement: stap 4, afbeelding 2 van 3 iDevices iGrill Probe Replacement: stap 4, afbeelding 3 van 3
    • If you have not removed the 2 silver-colored screws; you must remove them now.
    • Remove the metal terminals from the battery slot closest you.
    • Pull the remaining metal terminals out of their slots. Position them such that when removing the internal cover they will not be caught.
    • Remove the internal cover.
  5. iDevices iGrill Probe Replacement: stap 5, afbeelding 1 van 1
    • After the internal plastic case has been removed, you will have access to the probe contacts.
    • You should then insert the probes to check their connection to the probe terminals.
  6. iDevices iGrill Probe Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using a pair of tweezers, bend the probe contacts back in place. The tweezers will touch the probe terminals when inserted.
Conclusie
Michelle Nguyen
204 Reputatie
2 handleidingen geschreven
IUPUI, Team 3-4, Harley Spring 2016 Lid van IUPUI, Team 3-4, Harley Spring 2016
IUPUI-HARLEY-S16S3G4
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 1,085
