Ga door naar hoofdinhoud
iDeaUSA CT8 Speaker Replacement
Wat je nodig hebt
  1. iDeaUSA CT8 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 3 iDeaUSA CT8 Speaker Replacement, Speaker: stap 1, afbeelding 2 van 3 iDeaUSA CT8 Speaker Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Place the tablet on a flat surface, facing upwards.
    • Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
    • Place the front and back portion of the tablet close in proximity and have both of them face upwards while being cautious of the wire connecting the speaker to the motherboard.
  2. iDeaUSA CT8 Speaker Replacement: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Locate the two wires connecting the speaker to the motherboard.
    • With tweezers, gently pull the red and black wires out of their sockets.
    • A soldering kit is required to reconnect the speaker to the motherboard.
  3. iDeaUSA CT8 Speaker Replacement: stap 3, afbeelding 1 van 2 iDeaUSA CT8 Speaker Replacement: stap 3, afbeelding 2 van 2
    • On the tablet’s back cover, locate the two 4 mm screws on the speaker.
    • Use the #000 Phillips screwdriver to remove the screws and place them in an appropriate location.
  4. iDeaUSA CT8 Speaker Replacement: stap 4, afbeelding 1 van 2 iDeaUSA CT8 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Using a metal spudger, safely separate the speaker from its socket.
  5. iDeaUSA CT8 Speaker Replacement: stap 5, afbeelding 1 van 2 iDeaUSA CT8 Speaker Replacement: stap 5, afbeelding 2 van 2
    • The speaker is now removed and can be replaced accordingly.
    • Remember that to ensure a connection, you will need to solder the new wire connections onto the motherboard.
Conclusie
To reassemble your device, follow these instructions in reverse order. A soldering kit will be required to ensure a connection between the speaker and motherboard after the replacement is complete.
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 15
Altijd: 186
