Ga door naar hoofdinhoud
iDea USA CT 1020 Front & Rear Camera Assembly Replacement
Wat je nodig hebt
  1. iDea USA CT 1020 Front & Rear Camera Assembly Replacement, Front & Rear Camera Assembly: stap 1, afbeelding 1 van 1
    • First, power down the tablet to avoid the chance of electrical shock or damaging the machine during repair work
    • Place the tablet on a clean surface with the screen down
  2. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: stap 2, afbeelding 1 van 2 iDea USA CT 1020 Front & Rear Camera Assembly Replacement: stap 2, afbeelding 2 van 2
    • Remove the back plastic casing of the tablet by releasing the plastic clips with a plastic opening tool or a spudger.
    • Be cautious and take your time here; the plastic clips are quite fragile.
  3. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool or spudger to lift and release the camera assembly ZIF tab.
    • Gently pull the ribbon cable free.
  4. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: stap 4, afbeelding 1 van 2 iDea USA CT 1020 Front & Rear Camera Assembly Replacement: stap 4, afbeelding 2 van 2
    • The camera is held in place by adhesive material on the back of the camera
    • To complete removal, peel the camera off the mother board
Conclusie
Één andere persoon heeft deze handleiding voltooid.
David Lawrence
109 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G3, Freund Spring 2018 Lid van IUPUI, Team S1-G3, Freund Spring 2018
IUPUI-FREUND-S18S1G3
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 102
