Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je iControl Networks Piper te repareren, gebruik onze reparatiehandleidingen.
  1. iControl Networks Piper Teardown, Cracking Open The Case: stap 1, afbeelding 1 van 1
    • Piper is held together with four "security Philips" screws located in the battery case. Each screw has a post in the middle, meant to foil use of a standard screwdriver. However....
    • If you don't have the right bit, just use a large #2 philips head screwdriver: the bit won't go deep enough to get tangled up in the security feature.
    • Once the screws are out use a plastic spludger to pry open four plastic clips holding the shell together.
    Vraag FixBot
    Voeg opmerking toe
  2. iControl Networks Piper Teardown, What's Inside: stap 2, afbeelding 1 van 3 iControl Networks Piper Teardown, What's Inside: stap 2, afbeelding 2 van 3 iControl Networks Piper Teardown, What's Inside: stap 2, afbeelding 3 van 3
    • Piper is dominated by a large speaker, and a Mallory PS-953Q security horn. It's loud. The CPU is a Texas Instruments TMS320DM365 media processor with a ZW0301 based Z-Wave module.
    • Piper uses two tiny antennas, one for Z-Wave one for WiFi.
    • That's it... a pretty simple layout.
    Vraag FixBot
    Voeg opmerking toe
Bryce Nesbitt
1.244 Reputatie
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 2,511
