Ga door naar hoofdinhoud
iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement
Wat je nodig hebt
  1. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery out of the computer.
  3. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement, Rear Display Bezel: stap 3, afbeelding 1 van 2 iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement, Rear Display Bezel: stap 3, afbeelding 2 van 2
    • Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  4. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: stap 4, afbeelding 1 van 2 iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: stap 4, afbeelding 2 van 2
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  5. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: stap 5, afbeelding 1 van 1
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  6. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: stap 6, afbeelding 1 van 2 iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: stap 6, afbeelding 2 van 2
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  7. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: stap 7, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  8. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: stap 8, afbeelding 1 van 1
    • Lift the rear bezel off the display assembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bijgevoegde documenten
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,415
