Inleiding
Replace the display inverter with the display assembly still attached to your computer.
Gereedschap
Onderdelen
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
Close the display.
Remove the several pieces of tape securing the thin metal LCD cover to the display.
Carefully remove the piece of foil tape covering the display data cable connection.
Remove the two pieces of yellow tape covering the inverter/AirPort cables.
3 andere personen hebben deze handleiding voltooid.
