Inleiding
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the following 9 screws on the bottom of the computer:
Three 3 mm Phillips around the battery compartment.
Three 5 mm Phillips on the left and bottom edges.
Three 14.5 mm Phillips on the top and right edges (you may have to peel back the foil tape to reveal the screw near the security lock slot).
Remove the single Phillips screw on the left side of the fan.
Lift the fan out of its housing and disconnect it from the logic board.
