Ga door naar hoofdinhoud
iBook G3 14" Airport Card Replacement
Wat je nodig hebt
  1. iBook G3 14" Airport Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G3 14" Airport Card Replacement, Airport Card: stap 2, afbeelding 1 van 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G3 14" Airport Card Replacement: stap 3, afbeelding 1 van 1
    • If your computer does not have an Airport card installed, skip to the RAM shield removal step.
    • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
  4. iBook G3 14" Airport Card Replacement: stap 4, afbeelding 1 van 1
    • Grasp the clear plastic tab on the Airport card and pull toward the right.
  5. iBook G3 14" Airport Card Replacement: stap 5, afbeelding 1 van 1
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 8,007
