Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Replace a broken LCD/Backlight with the display still attached to your iBook.
Wat je nodig hebt
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Close the display.
Remove the small pieces of yellow tape securing the thin metal LCD cover to the display.
Remove the large piece of tape near the right display hinge.
12 andere personen hebben deze handleiding voltooid.
