Ga door naar hoofdinhoud
iBook G3 12" LCD Replacement
Wat je nodig hebt
  1. iBook G3 12" LCD Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G3 12" LCD Replacement, Rear Display Bezel: stap 2, afbeelding 1 van 2 iBook G3 12" LCD Replacement, Rear Display Bezel: stap 2, afbeelding 2 van 2
    • Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  3. iBook G3 12" LCD Replacement: stap 3, afbeelding 1 van 2 iBook G3 12" LCD Replacement: stap 3, afbeelding 2 van 2
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  4. iBook G3 12" LCD Replacement: stap 4, afbeelding 1 van 1
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  5. iBook G3 12" LCD Replacement: stap 5, afbeelding 1 van 2 iBook G3 12" LCD Replacement: stap 5, afbeelding 2 van 2
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  6. iBook G3 12" LCD Replacement: stap 6, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  7. iBook G3 12" LCD Replacement: stap 7, afbeelding 1 van 1
    • Lift the rear bezel off the display assembly.
  8. iBook G3 12" LCD Replacement, LCD: stap 8, afbeelding 1 van 2 iBook G3 12" LCD Replacement, LCD: stap 8, afbeelding 2 van 2
    • Close the display.
    • Remove the small pieces of yellow tape securing the thin metal LCD cover to the display.
    • Remove the large piece of tape near the right display hinge.
  9. iBook G3 12" LCD Replacement: stap 9, afbeelding 1 van 2 iBook G3 12" LCD Replacement: stap 9, afbeelding 2 van 2
    • Remove the tape covering the inverter cable connector.
    • Remove the piece of foil tape near the center of the thin metal LCD cover.
  10. iBook G3 12" LCD Replacement: stap 10, afbeelding 1 van 2 iBook G3 12" LCD Replacement: stap 10, afbeelding 2 van 2
    • Remove the Phillips screw near the right display hinge.
    • Use the tip of a spudger to remove the small spacer under the screw you just removed.
  11. iBook G3 12" LCD Replacement: stap 11, afbeelding 1 van 2 iBook G3 12" LCD Replacement: stap 11, afbeelding 2 van 2
    • Pull the foil/braided pieces of tape off the aluminum frame of the clutch hinges. Leave the tape attached to the thin steel LCD cover.
    • Remove the small piece of tape holding the display data cable ground strap to the LCD cover.
  12. iBook G3 12" LCD Replacement: stap 12, afbeelding 1 van 2 iBook G3 12" LCD Replacement: stap 12, afbeelding 2 van 2
    • Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total).
  13. iBook G3 12" LCD Replacement: stap 13, afbeelding 1 van 1
    • Carefully remove the thin steel LCD cover.
  14. iBook G3 12" LCD Replacement: stap 14, afbeelding 1 van 2 iBook G3 12" LCD Replacement: stap 14, afbeelding 2 van 2
    • Remove the long piece of tape securing the display data cable to the LCD.
    • Disconnect the display data cable by pulling the cable away from the socket on the LCD.
  15. iBook G3 12" LCD Replacement: stap 15, afbeelding 1 van 1
    • Disconnect the backlight cable from the inverter.
    • It is helpful to use a spudger to push the backlight connector away from its socket while you lightly pull its cables away from the inverter.
  16. iBook G3 12" LCD Replacement: stap 16, afbeelding 1 van 3 iBook G3 12" LCD Replacement: stap 16, afbeelding 2 van 3 iBook G3 12" LCD Replacement: stap 16, afbeelding 3 van 3
    • Open the display.
    • Lift the LCD out of the display assembly.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 34
Altijd: 11,746
