Inleiding
Replace a faulty display inverter with the display attached to your iBook.
Gereedschap
Onderdelen
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Close the display.
Remove the small pieces of yellow tape securing the thin metal LCD cover to the display.
Remove the large piece of tape near the right display hinge.
Remove the pieces of tape holding the inverter and the inverter cables to the clutch hinges.
6 andere personen hebben deze handleiding voltooid.
