Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide has some missing steps. Check out the comprehensive iPhone 4S Screen Replacement Guide.
Onderdelen
Geen onderdelen opgegeven.
  1. I phone 4s, A1837 Magnetic Screw Mat Magnetic Screw Mat
    • I phone 4s, A1837
    • Magnetic Screw Mat
  2. Remove 2 X pentalobe screws Remove 2 X pentalobe screws Remove 2 X pentalobe screws
    • Remove 2 X pentalobe screws
  3. Slide rear cover up and remove Slide rear cover up and remove
    • Slide rear cover up and remove
  4. Remove 2 X Philips screws Remove connector Remove connector
    • Remove 2 X Philips screws
    • Remove connector
  5. OPEN ALLE TABBLADEN
    RAM-upgradekits voor Mac
    Koop kits
    Genoeg RAM
    voor al je tabbladen
    Koop kits
  6. Pull battery removal tab up to remove battery Pull battery removal tab up to remove battery Pull battery removal tab up to remove battery
    • Pull battery removal tab up to remove battery
  7. Remove 2 X Philips screws and plate Pop up connector and slide tool underneath ribbon cable to remove glue Pop up connector and slide tool underneath ribbon cable to remove glue
    • Remove 2 X Philips screws and plate
    • Pop up connector and slide tool underneath ribbon cable to remove glue
  8. Remove wifi antenna Remove wifi antenna Remove wifi antenna
    • Remove wifi antenna
  9. Remove camera and Sim card Remove camera and Sim card Remove camera and Sim card
    • Remove camera and Sim card
  10. Pop up 6 connectors at the top
    • Pop up 6 connectors at the top
  11. Remove 2 X screws and triangular washer Remove 2 X screws and triangular washer
    • Remove 2 X screws and triangular washer
  12. Heat vibrator and pry up Heat vibrator and pry up
    • Heat vibrator and pry up
  13. Remove 10 X Philips screws Remove 10 X Philips screws
    • Remove 10 X Philips screws
Conclusie
6 andere personen hebben deze handleiding voltooid.
Shane
844 Reputatie
1 Handleiding geschreven
Smart Screens Lid van Smart Screens
Business
1 Lid
1 handleiding geschreven
Één commentaar
I know the user had good intentions, but this is a low quality guide. Low lighting, super vagueness in steps, not all steps necessary are listed, screws to remove, harmful surprises to expect etc. If you want to replace your screen successfully with confidence and ease, use ifixit's staff guide: iPhone 4S Screen Replacement
lucasproul - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 4,849
