Ga door naar hoofdinhoud
hp pavilion 15-cc023cl Motherboard Replacement
Wat je nodig hebt
  1. hp pavilion 15-cc023cl Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 hp pavilion 15-cc023cl Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. hp pavilion 15-cc023cl Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. hp pavilion 15-cc023cl Motherboard Replacement: stap 3, afbeelding 1 van 2 hp pavilion 15-cc023cl Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. hp pavilion 15-cc023cl Motherboard Replacement: stap 4, afbeelding 1 van 2 hp pavilion 15-cc023cl Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. hp pavilion 15-cc023cl Motherboard Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. hp pavilion 15-cc023cl Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use a plastic opening tool to pry the hard drive out.
  7. hp pavilion 15-cc023cl Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the hard drive cable.
  8. hp pavilion 15-cc023cl Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Lift the plastic wedges up on both sides of the hard drive.
  9. hp pavilion 15-cc023cl Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • Locate the motherboard.
  10. hp pavilion 15-cc023cl Motherboard Replacement: stap 10, afbeelding 1 van 2 hp pavilion 15-cc023cl Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Use a PH0 screwdriver to unscrew the three 3 mm Phillips head screws located on the fan.
  11. hp pavilion 15-cc023cl Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Use a PH1 screwdriver to unscrew the four 3mm Phillips head screws located on the processor cover.
    • Disconnect the cable.
  12. hp pavilion 15-cc023cl Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Disconnect the plastic arm attached to the processor and remove.
    • Disconnect the cable attaching the fan to the motherboard and remove.
  13. hp pavilion 15-cc023cl Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Use a PH1 screwdriver to unscrew one 3mm Phillips head screws on Wifi card.
    • Disconnect the Wifi card.
    • Be careful not to break any of the connectors.
  14. hp pavilion 15-cc023cl Motherboard Replacement: stap 14, afbeelding 1 van 3 hp pavilion 15-cc023cl Motherboard Replacement: stap 14, afbeelding 2 van 3 hp pavilion 15-cc023cl Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Disconnect the 5 cables to keyboard and speakers.
    • You may have to pry some up with the spudger.
  15. hp pavilion 15-cc023cl Motherboard Replacement: stap 15, afbeelding 1 van 2 hp pavilion 15-cc023cl Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Use a PH1 screwdriver to unscrew six 3 mm Phillips head screws on the motherboard.
  16. hp pavilion 15-cc023cl Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Use the iFixit opening tools to pry motherboard from back of laptop.
  17. hp pavilion 15-cc023cl Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Disconnect SD and USB card cable.
Conclusie
2 opmerkingen
Good job Stephany. I would’ve been lost without you…
your friend eternally,
Richey Dale
richeydale67 - Antwoord
How can i get this model motherboard
Adeyinka Alasi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 1,397
