Ga door naar hoofdinhoud
Help
Nexus 7 Display Assembly Replacement
Replace the Display Assembly in your Nexus 7.
  • Auteur: Brett Hartt
  • Geschatte tijd: 20 minuten - 1 uur
  • Moeilijkheid: Gemiddeld
A broken display is something that every tablet owner has nightmares over. Use this guide to replace a damaged, faulty, or broken display assembly (includes the LCD and digitizer).
Stap 1 Display Assembly  ¶
Peel the upper piece of black adhesive tape completely up off the Nexus 7. Similarly, peel the lower piece of black adhesive tape, but only as far as the copper strip.
  • Peel the upper piece of black adhesive tape completely up off the Nexus 7.
  • Similarly, peel the lower piece of black adhesive tape, but only as far as the copper strip.
  • It is helpful to fold this piece of tape back on itself to keep it out of the way.
  • Whilst pulling the tape, be sure that the metal shield does not lift up. Hold the shield in place, and if it lifts up, re-seat it in the spring clips around the perimeter of the shielded area.
Stap 2  ¶
Use the flat end of a spudger to pry the display data cable straight up off its socket on the motherboard.
Stap 2  ¶
  • Use the flat end of a spudger to pry the display data cable straight up off its socket on the motherboard.
Stap 3  ¶
Use the flat end of a spudger to carefully flip up the retaining flaps on the digitizer ribbon cable ZIF sockets. Make sure you are flipping up the white retaining flaps, not the black sockets themselves. Use the tip of a spudger to pull the digitizer ribbon cable straight out of its socket.
Stap 3  ¶
  • Use the flat end of a spudger to carefully flip up the retaining flaps on the digitizer ribbon cable ZIF sockets.
  • Make sure you are flipping up the white retaining flaps, not the black sockets themselves.
  • Use the tip of a spudger to pull the digitizer ribbon cable straight out of its socket.
Stap 4  ¶
Remove the following screws securing the display assembly to the metal frame: Thirteen 3.2 mm silver Phillips screws
Stap 4  ¶
  • Remove the following screws securing the display assembly to the metal frame:
  • Thirteen 3.2 mm silver Phillips screws
  • Two 4.25 mm black Phillips screws
  • In 3G models, the two top-center Phillips screws are slightly lower and on top of the motherboard.
  • Note that the assembly for the non-3G model will NOT fit the 3G model. When looking for the 3G assembly, look for model 'ME370TG', and note that in pictures of the 3G verison the top 2 phillips screw holes are slightly lower than the upper right and left ones.
Stap 5  ¶
The display assembly is held in place by a large amount of adhesive on the underside of the large copper ESD shield. In the next few steps, you will be using a plastic spudger to release this adhesive.
Stap 5  ¶
  • The display assembly is held in place by a large amount of adhesive on the underside of the large copper ESD shield. In the next few steps, you will be using a plastic spudger to release this adhesive.
  • Work carefully and slowly, making sure to not break the I/O data cable.
Stap 6  ¶
Insert a plastic spudger on the left side of the Nexus 7, near the bottom of the battery. Only insert the spudger enough to free the adhesive (about halfway across the Nexus 7)—if you go any farther, you may damage the LCD cable. Slide the spudger toward the top of the Nexus 7, releasing the adhesive as you go.
Stap 6  ¶
  • Insert a plastic spudger on the left side of the Nexus 7, near the bottom of the battery.
  • Only insert the spudger enough to free the adhesive (about halfway across the Nexus 7)—if you go any farther, you may damage the LCD cable.
  • Slide the spudger toward the top of the Nexus 7, releasing the adhesive as you go.
Stap 7  ¶
Carefully rotate the metal frame away from the display assembly, minding any cables that may get caught.
Stap 7  ¶
  • Carefully rotate the metal frame away from the display assembly, minding any cables that may get caught.
  • You may need to apply heat to the display assembly before lifting it away from the device.
  • Display assembly remains.
