Ga door naar hoofdinhoud
Help
PowerBook G4 Titanium DVI Modem Filter Board Replacement
  • Auteur: iRobot
  • Moeilijkheid: Gemiddeld
How to access the PowerBook G4 Ti DVI Modem Filter Board.
Stap 1 Modem Filter Board  ¶
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over and place it on the cloth.
  • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over and place it on the cloth.
  • Disconnect the four indicated connectors from the logic board.
  • The large multicolor cable may be difficult to free.
  • The top center cable may not need to be disconnected to remove the modem filter board. It connects to the logic board fan to its immediate left, which is attached to the logic board itself.
Stap 2  ¶
Remove the T8 Torx screw near the heat pipe.
Stap 2  ¶
  • Remove the T8 Torx screw near the heat pipe.
Stap 3  ¶
Disconnect the two connectors from the modem filter board.
Stap 3  ¶
  • Disconnect the two connectors from the modem filter board.
  • To the immediate right of the modem filter board, the heatsink has two sets of five fins with a double-wide space in between them. This space is where the gray & black coiled wire is supposed to go to ensure a flush fit.
Stap 4  ¶
Remove the T6 Torx screw from the modem filter board.
Stap 4  ¶
  • Remove the T6 Torx screw from the modem filter board.
Stap 5  ¶
Remove the modem filter board from the computer by pulling up and to the right.
Stap 5  ¶
  • Remove the modem filter board from the computer by pulling up and to the right.
  • There is a small plastic post which helps hold the modem filter board in place. You need to clear this post to remove the modem filter board from the computer.
