Ga door naar hoofdinhoud
Help
Motorola Atrix 4G Battery Replacement
This guide will attempt to help individuals in successfully replacing the battery in a Motorola Atrix 4G phone.
This guide will show you how to remove the battery from the Motorola Atrix 4G.
Gereedschap
Stap 1 Battery  ¶
Pry the rear cover from the back of the phone.
Stap 1 Battery  ¶
  • Pry the rear cover from the back of the phone.
Stap 2  ¶
Insert a spudger or plastic opening tool into the small notch at the base of the battery. Lift the battery out of the phone.
Stap 2  ¶
  • Insert a spudger or plastic opening tool into the small notch at the base of the battery.
  • Lift the battery out of the phone.
