Help
Removing Nikon Coolpix 4600 Front and Rear case
Actiemomenten
Actiemomenten
Wees een actieheld! Deze handleiding heeft plaatjes nodig die beter tonen hoe specifieke handelingen uitgevoerd moeten worden.
Gives a step by step procedure to remove the front and rear case for other internal repairs.
  • Auteur: Nathan Sperling
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Eenvoudig
This installation guide will help you remove the rear and front casing of your Nikon Coolpix 4600.
Stap 1 Front and Rear Case  ¶
Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right). Using a Phillips 00 screwdriver, remove all of the six screws.
  • Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
  • Using a Phillips 00 screwdriver, remove all of the six screws.
Stap 2  ¶
Carefully pull the front and back case apart. The front case is attached to internal components and cannot be removed independently.
Stap 2  ¶
  • Carefully pull the front and back case apart.
  • The front case is attached to internal components and cannot be removed independently.
Stap 3  ¶
Look closely at the connection between the ribbon cable and the motherboard.  Locate the two grey tabs on either side of the connecting bracket.
Stap 3  ¶
  • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
  • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
  • After disconnecting the data ribbon, you can now separate the back case from the front case.
