Help
Nikon Coolpix 4600 LCD screen Replacement
Actiemomenten
Actiemomenten
Wees een actieheld! Deze handleiding heeft plaatjes nodig die beter tonen hoe specifieke handelingen uitgevoerd moeten worden.
Verwarrende Tekst
Verwarrende Tekst
Een deel van de tekst in deze handleiding is verwarrend, dubbelop of naast de kwestie. Bewerk de tekst en maak hem duidelijker!
Er moeten meer foto's
Een paar extra plaatjes zouden de procedure in deze handleiding glashelder maken.
This guide will give step by step instructions to replace a broken LCD screen in a Nikon Coolpix 4600 camera.
  • Auteur: Nathan Sperling
  • Geschatte tijd: 15 - 30 minuten
  • Moeilijkheid: Gemiddeld
This installation guide will help you remove and replace the LCD screen of your Nikon Coolpix 4600 camera.
Stap 1 LCD screen  ¶
With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen (left side of the screen will be glued down).
Stap 1 LCD screen  ¶
  • With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen (left side of the screen will be glued down).
  • Be careful not to push the front case too hard on the table when taking the LCD out or the lens will get stuck.
  • Insert plastic tool under the screen and gently pry up the left side of the screen until the glue seal is broken.
Stap 2  ¶
Locate the orange ribbon cable and two wires (red and white) attached to the motherboard.
Stap 2  ¶
  • Locate the orange ribbon cable and two wires (red and white) attached to the motherboard.
  • Lift up on the black clamp and pull out data cable.
  • Desolder the wires from motherboard. CAUTION: Improper desoldering can result in motherboard damage. Seek help if you do not have the necessary skills.
  • The screen should now be completely free from the camera.
